Results 1 to 5 of 5
Thread: MACROS
    Jun 2008
    MACROS
    WHEN HITTING MACRO SOFT KEY ON MSG 803 CONTROL PANEL OR OTHER MORI CONTROL PANELS AND THEY SHOW 101 THRU 115, ARE THOSE THE NUMBER OF MACROS YOU ARE ALLOWED TO USE SUCH AS P9101 THRU P9115 ? WE GOT A MORI WITH NO MANUAL AND TRYING TO FIGURE THINGS OUT ! PLEASE HELP
    May 2007
    Don't know a thing about that control, but once on the macro page, try typing in 500 and hitting the search key (or down arrow key). On a Fanuc it will take you to the 500 series macros.
    On a Fanuc P9101, etc. have nothing to do with macros. You can call up a subprogram with M98P9101 or call up a subprogram and assign values to variables within the subprogram by using a G65 Macro Call such as G65P9314A.5K-1.1B.02F.009
    There are 9000 series macros (on a Fanuc), but they would be referred to by something like Parameter 9101 bit 4 or possibly Para 9101.4
    I suppose if the thread subject was Parameters you probably could write P9101.4 and everyone would understand what you meant.
    Jul 2011
    They are most likely Macro variables and their contents.
    Jan 2011
    The MSG803 is a Mitsubishi M64 CNC and when the machine was purchased new the total number of available variables was sold as an option.
    The local variables #1 -#33 were standard
    Comman variables #100 - #149 and #500 - #549 were standard
    additional variables came in increments of
    200, 300, 600, 700 sets.
    If you found the macro variable screen you should see the #1 to 33
    and at least the 100-149 and 500-549 you can see all the variables
    available when you hit the page down key on this screen.
    If you need more variables the option can still be purchased.
    Jul 2011
    camsys
    I was trying to post an answer to gtrrpa, thanks for the prompt attention though
    1. New to using Macros
      By 905xray in forum G-Code Programing
      Last Post: 12-08-2009, 02:35 PM
    2. Need Help!- X3 CNC macros
      By trainfred in forum Syil Products
      Last Post: 05-20-2008, 08:42 PM
    3. Need Help!- help with macros
      By gj83 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 04-11-2008, 09:42 PM
    4. Need Help!- macros
      By bob@apc in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 02-04-2008, 12:42 PM
    5. Macros
      By cncfreak in forum General CAM Discussion
      Last Post: 05-06-2005, 06:04 PM
