Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 03-05-2011, 05:01 AM
bbrreid is on a distinguished road
max turning diameter
I have a 1983 Mori Seki SL3 lathe with Fanuc 6T (A) control
can anyone tell me the max diameter you can turn on this machine,
I have seen so many different statements on the web like 9" 10" even up to 15" when I home the "x" it stops at -172.8mm(6.803") does this mean I can turn approx 12" diameter ?
thanks
BR
Old 03-05-2011, 05:48 AM
zooloader's Avatar
zooloader is on a distinguished road
I have a piece of string.
I can hold each end in my hands.
I've been "Googling" it all day, and now I'm really confused.
Can anyone tell me how long it is?
Pretty please?
Old 03-05-2011, 07:04 AM
w_bloemen is on a distinguished road
What are the reference points when booting the machine?
Usually it goes to the outer limits of the machine.
Otherwise, try to search a more specific description of the machine.
There's probably a solid picture with more data perhaps even the maximum diameter
Old 03-05-2011, 09:10 PM
Waynno is on a distinguished road
10 inch general max turn for SL-3 model
Sometimes you can modify a tool holder to get a bit more depending on the length of
workpiece and material properties.
There are other variables such as turret interference with adjacent tooling and chuck/clamping configuration.
Generally I try to stick with 10 inch max on my SL-3 just to play it safe
Wayne
http://nosala.com
The Mori Seiki Underground Message Board
Old 03-08-2011, 02:05 PM
Thank you for your helpful replies (apart from one) 8" is the max I can manage on my SL3
BR
turning .003 diameter brass wire camtd CNC Swiss Screw Machines 3 06-14-2008 12:15 PM
Shaft Diameter, LeadScrew Diameter, Motor Torque? cnc-newb DIY-CNC Router Table Machines 8 12-24-2007 02:51 PM
Shaft Diameter, LeadScrew Diameter, Motor Torque? cnc-newb General Metal Working Machines 0 12-14-2007 09:25 PM
turning motor shaft to smaller diameter smoker General Material Machining Solutions 5 03-08-2007 09:56 PM
Turning smaller diameter delrin? conceptmachinin General Material Machining Solutions 29 03-08-2007 02:02 PM
