Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 03-02-2011, 12:46 PM
repbob is on a distinguished road
spindle doesn't stop with reset
HI everybody,
I have a lathe Hiatchi, when we push the reset buton the program stop but the spindel doesn't(we have to stop it manualy).The control is a Fanuc 10
Does anybody know if there is a parameter to solve this. Hitachi doesn't exist anymore and all the documentation for this mchine has been lost
Thank's
Repbob
Old 03-03-2011, 10:05 AM
sld4121 is on a distinguished road
Most likely it is a keep relay.
I would suggest you have someone peruse the ladder.
If Hitachi documented the ladder the way most builders do, it should be easy to spot.
Old 03-03-2011, 11:28 AM
thank you SLD4121,
I already tried to have a look to the lader and at that time I didn't find the place where i could make a change with keep relay.
Repbob
Old 03-03-2011, 04:55 PM
cncserveng is on a distinguished road
The enable (run) signal on a spindle drive is usually a 24vdc signal that is removed from the input i.e. the signal goes "low".
As SLD has said it could be a sticking relay, or a bad PMC output, you need to check for this drive input on the spindle drive wiring diagram.
btw; does it stop with "S0 M5" ??
Old 03-04-2011, 12:14 PM
@cncsereng
Thank's for your help, but it is not a "hardware" problem; it as to do with the way the machine has been set by the machine builder or a fanuc parameter.
No the machine doesn't stop with M5.I have to put the machine in jog mode and push the spindle stop buton.
Repbob.
Old 03-23-2011, 08:31 PM
cnc doc is on a distinguished road
download your ladder file and post on your next post. we can look at your ladder of line and check the keep relays. also if you don't have a wiring diagram we can get you a list of all addresses inputs, outputs, keep relays and more and save them in notepad so that you could have them. when you open the ladder file of line you can scroll threw the entire list of keep relays.
Old 03-24-2011, 01:05 PM
Hello CNC Doc,
thank's for your proposition, but I don't know how to download the ladder on this control (fanuc 10),can you explain how to do it?
Best regards.
Repbob
reset emergency stop jeffm Fanuc 8 07-05-2010 11:34 PM
E-stop will not reset?? Barefootboy4 DIY-CNC Router Table Machines 38 01-15-2010 03:25 PM
VMC-750 E-stop won't reset blackbolt9 Cincinnati CNC 3 08-03-2009 08:54 AM
Need Help!- Spindle stop (M5) and coolant off (M9) by Reset button (0-MC) padobranac Fanuc 10 10-24-2008 10:11 AM
X2 spindle popping reset cyclestart Benchtop Machines 3 03-17-2008 02:48 PM
