Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 02-17-2011, 09:08 PM
Kp Carmichael is on a distinguished road
Alarms 414 and 424 after running 8 hrs
Can anyone tell me what is going on? I have a Sl-25B and after it runs about 8 hours it stops with 414 servo alarm X axis detect error, and 424 servo alarm Z axis detect error. will not clear untill it rest for about 8 hours. I thought it might be overheating so I replaced cooling fans, no change. I no longer think it is cooling issue because if you let it set 2 or 3 hours the errors will not clear. Needs 8 hrs or more. It like its on a timer.
Thanks, Kp
Old 03-12-2011, 11:33 AM
underthetire is on a distinguished road
What control? Alpha drives or c series?
Old 03-14-2011, 10:58 AM
How can I tell? the control is a Mori MF-T4 Fanuc 0TC 1990 model year.
Old 03-14-2011, 11:11 AM
Al_The_Man's Avatar
The particular faults for 4x4 alarms can be monitored in DGN registers 720 - 723.
for each axis.
The bits that are on indicate the cause of the alarm.
on the C series 730 -737 also have a couple of bits to check.
Old 03-21-2011, 11:39 AM
for each axis.
Man what are DGN registers, where are they and how do you understand their meaning? kp
Old 03-21-2011, 04:44 PM
Al_The_Man's Avatar
The 720~723 are found in the Diagnostic screen, they are for each of four axis.
bit 0= OFAL
1=FBAL
2=DCAL
3=HVAL
4=HCAL
5=OVC
6=LV
7=OVL.
You really need the servo maintenance manual for each interpretation, but if you post what they show, I can look them up.
Over heat, Over current etc.
Old 03-23-2011, 08:20 PM
cnc doc is on a distinguished road
does this machine happen to have seperate detectors. perhaps that would tie the two together if it had an optional seperate detector module that is failing.
Need Help!- alarms kling8 Fadal 2 10-27-2009 10:22 AM
Need Help!- Alarms sjj Mazak, Mitsubishi, Mazatrol 1 09-02-2009 08:16 AM
ALARMS ALARMS ALARMS tunitime Okuma 5 08-05-2009 11:37 AM
310,320 alarms CHANDRU Fanuc 2 11-28-2008 02:26 AM
ALARMS 250 and 251 Geof Haas Lathes 5 02-15-2008 09:32 AM
