Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 01-29-2011, 04:53 PM
nlh nlh is offline
nlh is on a distinguished road
Spindle drive compatability
As per some of my previous post in this forum I have an SL-1A I have been trying to get going. It has a bad spindle drive. I was able to somehow bypass the not ready signal coming from the drive and jog the machine around without issue. Becuase of this I have decided to replace the spindle drive and put the machine into use.
My first question is this. Will a spindle drive of the same model that was from a milling machine, fit and work properly in a lathe application?
I have located a drive, it is a CIMR-MTII-7.5K.B. My old drive is just a CIMR-MTII-7.5K.
Is the B series drive compatible with a "non B series" drive? The B drive has a blue metal cover whereas the "old" one has a clear plastic cover.
I won't contact Yaskawa on this. I have tried a couple times but no one wants to be bothered with such an old machine. They would rather sell me a new one for $10,500.
Any insight would be appreciated.
Thanks!
Old 02-02-2011, 11:37 AM
nlh nlh is offline
No one out there has any info on this?
Old 02-02-2011, 12:07 PM
Waynno is on a distinguished road
Its probably doable, But you would need specific documentation
from Yaskawa on the pin configuration on the newer drive
I did one of these a few years ago, took a chance and bought
a brand new drive off Ebay for about $400.00, But is came with
a manual.
I described to the seller what I was doing with the drive, he said
I needed a plug to convert from the temenal strip style connection
to the plug they were using at the time.
The manual has all the pin functions, I made up a cable and mounted
a new terminal strip in the box to make the connections.
I also had to but a specific encoder to replace the tach, that in itself
was $700.00
But I got it all to go, 1500.00 I paid for the machine with the blown drive
$400.00 for the new/surplus drive Ebay score, $700.00 for the encoder
and a lot of patience and self re-acquittance from my training in electronics
and digital electronics 20 years earlier, I still have the machine, it runs rather
good for small investment and a lot of time tinkering with the drive
I know this may not help your situation, but maybe a bit more persistence
with Yaskawa to get the manual for the newer drive may pay off, they used
to give manuals for free, have not delt with them for a few years, not sure
if they still do that
Wayne
http://nosala.com
The Mori Seiki Underground Message Board
Old 02-02-2011, 07:58 PM
nlh nlh is offline
Thanks Waynno,
Actually, now that you mention it, I downloaded a couple drive manuals from Yaskawa's website a while back. I'm pretty sure all the pin-out info is in the manuals (just took a look before replying).
I do like your idea of retrofitting a new drive. I'm comfortable enough with electronic's to not let some rewiring stop me, however it's also a time issue. An exact replacement drive would be a little more money but would be a 20 min replacement.
A question concerning your machine and retrofit. Is it absolutely mandatory to have a spindle encoder feeding back to the drive? There is another thread in the Mazak forum about retrofitting a Toshiba VFS11 drive. However, this drive doesn't use feedback but supposedly with careful tuning can be very accurate. It's refered to as a "Sensorless Vector" vfd.
Still need to do some more exploring before I jump in.
Thanks again,
Nate
Old 02-02-2011, 08:17 PM
In my case, Yes, it was absolutely required
Your case, no way to tell until you find documentation for that
specific drive. You may get away with your current brush tach on
that vintage
Wayne
http://nosala.com
Old 02-02-2011, 09:12 PM
BTW, Here is some video I took of that very machine the other night
YouTube - Sl 1 0001
http://nosala.com
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
UM Baldor servo drive, servo compatability dingo0722 Servo Motors and Drives 0 11-14-2010 08:12 PM
FANUC OT B Spindle rpm fluctuating and causing 1008 Spindle Drive Fault Bill Gillen Fanuc 4 10-15-2010 01:10 PM
chinese drive voltage compatability dix2111 Phase Converters and VFD 3 09-05-2010 12:43 PM
servo drive compatability miljnor Servo Drives 85 05-03-2006 12:56 AM
