Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 01-28-2011, 10:34 PM
thesaurian is on a distinguished road
Power problem perhaps
I just had a conversation with a local electrical worker and he suggested that maybe the problem I am having with my mori lathe is that the incoming power is maybe inappropriate for the lathe. We have no idea ourselves as to what is needed. Please advise!!
Old 01-29-2011, 10:10 AM
Al_The_Man's Avatar
It should be stamped on the MTB's Specification plate on the machine?
Old 01-29-2011, 12:54 PM
underthetire is on a distinguished road
Since my crystal ball is broken, can't help. Mori has been building cnc lathes since the late 60s, so kinda hard to say without info.
Old 01-30-2011, 01:54 PM
Our incoming power is 480 v 3 phase, stepped down to 220 via transformer. The serviceman was referring to the power being "Y" vs star. Any thoughts?
Old 01-30-2011, 02:23 PM
Al_The_Man's Avatar
All you need is 3 phase at the required voltage per phase.
Y Is Star, he probably mentioned Star (Y) or delta, otherwise known as Wye - Delta.
This is the configuration of the transformer secondary windings.
Either will work at the correct voltage as you should not need a neutral.
If this is a Mori with Fanuc 6 control, the phase sequence has to be correct.
Old 01-30-2011, 03:51 PM
All moris are phase sensitive, coolers, coolant pumps, and hydraulic systems need the correct phase. What is wrong with the mori? That's what we need.
Old 01-30-2011, 04:40 PM
Al_The_Man's Avatar
That true, but in the case of the SCR drives, if a phase rotation meter is not used before hook up, the velocity control unit, (servo's), misconnection will cause a blow out of F1.F2,F3.
Ref: 2.2.4 Fanuc 6 installation manual.
Old 01-31-2011, 08:01 AM
Mori Info
This is an 89 Mori with 220 3 phase coming from a step down transformer. After working the weekend on double checking parameters, etc, I have the chuck opening and closing, the tailstock moving in and out, the lube pump oiling, but the machine will not move in any axis. It called up a OT032 NEED ZRN(ABS PCDR).
I was able to get ris of the alarm by changing para 1815 but am wondering if it referred not to a need to be zeroed but to the encoders not reading what the machine did. (based on internet searching.) I would like to be able to move each axis over the limit sensors, but without being able to move, it is kinda hard.
When we bought the machine, it came on transport, and there wasn't any blocking to support the turret, as they reccomend in the manual.
The positioning on the screen reads a few thousandths (.0023) on the x-axis.
Please and thanks in advance, the help I have been recieving over these forums is keeping me sane!!
Old 01-31-2011, 09:45 AM
Yes, you simply lost the zero return, no power issues. Axis have battery backup for position. On a 89, i'm guessing MFt4 control (ot ), or ?? There are procedures for it.
Fanuc W0 EDM Power problem. mossy123 EDM Machines 10 11-21-2010 03:22 PM
controller power problem mdred68 Tormach PCNC 2 06-27-2010 01:56 PM
Need Help!- Hurco Power Problem truckmann4x4 General Electronics Discussion 0 11-18-2009 07:41 AM
Problem- laser power problem desibrown Laser Engraving & Cutting Machines 5 12-08-2008 04:41 AM
Need Help!- TL-1 power supply problem rideredcr Haas Lathes 1 09-03-2008 01:48 AM
