Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 01-27-2011, 03:29 PM
thesaurian is on a distinguished road
SL25B
My mori has passed through its RAM parity issues and will not show any alarms, but there is no movement when I try and zero the machine. I just got this machine and Mori and Fanuc have been awesome at helping, but they are getting stumped on this. Any advice on things to try?
Old 01-27-2011, 03:47 PM
underthetire is on a distinguished road
I have a guess if that helps. Door interlock switch. Was probably turned of in the PMC parameters, and after your re-load it's back on. Or... turret index or turret not clamped. Is the TCL light on or flashing?
Old 01-27-2011, 07:44 PM
I am up for guesses or anything that could help. How do I check the door interlock or turret clamp. I am so close to getting this to fire up that I can almost taste it, and I appreciate the suggestion
Old 01-27-2011, 07:46 PM
The ERR light on the front of the machine is flashing, but the MRDY light is also on. Suggestions are very welcome!
Old 01-27-2011, 08:10 PM
If the error light is on, and there are no ex alarms, try to index the turret. It may need to be moved so the machine can re count it's current position.
Old 01-27-2011, 09:24 PM
I have tried to index the turret, but it does not move. I did not get parameters with the machine so mori sent me generic parameters, and as I said we got them input, butno movement is achieved. I can open and close the chuck and I can turn on the light and the chip conveyor, but the tailstock will not move in or out either. I used the parameter for programmable tailstock, but am unsure as to whether that could be the problem. When I power up, whatever mode I am in (MDI, jog, rapid, etc) shows up on the bottom of the screen with rset following it.
Old 01-31-2011, 09:38 AM
There are two tailstocks available. Programmable quill, and thats the standard. The other one was programmable tailstock spec. witch allowed you to control position of the actual body. If you put programmable type, the machine will not allow you to do anything, since it's looking for tailstock clamp witch wouldn't be there if its a standard spec.
Old 01-31-2011, 12:22 PM
Which tailstock
The tailstock I have has a steel dog on the front of it that you can tip and have the turret drag it to the proper location. Which one would this be? Programmable or not?
Old 01-31-2011, 12:23 PM
Not. thats the standard spec.
Old 01-31-2011, 03:16 PM
Switch not changing modes
The change of parameters doesn't seem to change things. The dial which toggles from edit to mdi to jog rapid and zero return doesn't seem to be picked up by the control. The bottom of the screen perpetually says MDI ****RSET****
In a lot of ways it is almost as if the buttons on the control are unresponsive. The turret clamp is on but doesn't allow to change tools , the dial pulse generator light doesn't come on when in dial mode, and the dial doesn't do anything.
Any thoughts?
  #11   Ban this user!
Old 01-31-2011, 04:26 PM
The reset is the give away. The machine is not ready, and still in reset mode. Most likely cause is either a barfeed problem if equipped, a door switch, or a parameter for the above. Can also just be a wrong PMC parameter for panel type, or even a timer.
  #12   Ban this user!
Old 01-31-2011, 05:43 PM
possibilities
These are all possibilities, just use a multimeter to gauge as to if all the limit switches are working, or are there other method of checking, as I mentioned there are no alarms coming up, and the only parameters I have are some generic ones that Ellison Technologies had on hand.
Need Help!- Mori Seiki SL25B mmxmb Mori lathes 1 09-14-2009 07:35 AM
