Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 01-22-2011, 11:52 PM
MrUZU1 is on a distinguished road
Talking SL 65 slow rapid
Any help with the parameter settings would be appreciated.
Old 01-27-2011, 01:57 PM
NL2000 is on a distinguished road
What control do you have?
Are you trying to increase or decrease the rapid speeds?
What axis are you trying to change?
Old 01-29-2011, 02:23 AM
Unhappy Speed them up!
It is a MF-T6 and I want to speed them up. I have tried to bump up the rapid traverse values in the parameter setting and it kicks out the servo and gives an alarm.I know most mori turning centers are capable of 196 ipm in x and more than that in z and we are nowhere near that.
Old 01-29-2011, 01:03 PM
underthetire is on a distinguished road
First, sl65 is a old big machine. You need to first check the parameters against the factory parameter list. If they are different, put them back to factory. If it kicks out your servos then, you have other major issues. My two guesses are ther was something mechanical wrong, so someone slowed them down to band aid it,,or the door interlock is not right so it's putting the rapids at half speed. These were never super fast machines though.
Need Help!- Mori-seiki SL65 Slow Rapid MrUZU1 General Metalwork Discussion 1 01-23-2011 07:48 PM
Problem- how do I slow the rapid gandrtooling Mazak, Mitsubishi, Mazatrol 5 09-07-2009 10:33 PM
Problem- rapid c axis movement slow chunkymonkey CNC Swiss Screw Machines 4 02-21-2009 02:02 AM
O mate M slow rapid rate Phase II diemaker Fanuc 0 10-18-2006 04:08 AM
O mate M slow rapid rate diemaker Fanuc 6 10-09-2006 02:14 PM
