Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 01-22-2011, 07:04 PM
Farmer Machine's Avatar
Farmer Machine is on a distinguished road
mori seiki cl 20 spindle runs erratic in reverse
I have a 1996 Mori Seiki cl 20 with a MSC 521/fanuc 21 tb control. The spindle tries to run in reverse but its movement is really erratic. It will run at speeds under 100 rpm, but the load meter fluctuates greatly. Anything over 100 rpm and the spindle runs forward for about one revolution and then reverse for about one revolution and continues this until you stop it. Forward runs fine MOST of the time. Sometimes it acts up in forward, but not nearly as severely. The problem in forward is usually high load on load meter and noise coming from spindle. It did it today and after running in forward for a couple of minutes it was ok, but the problem with reverse is always there. Oh by the way, I'm running this off a rotary phase converter with a 240 - 208 transformer that is tapped to balance voltages between 215 - 220. I have also replaced two of the three transistor modules in the spindle amp due to failure. When each of the two stopped working it stopped the spindle amp from working. I was thinking it may be that third transistor module, but so far it hasn't knocked out the drive completely. If anyone has any ideas i'd sure like to hear them. Thank you.
Old 01-22-2011, 07:51 PM
underthetire is on a distinguished road
That machine is just a straight fanuc 21 with a alpha spindle drive. No built in sensors or anything that can cause that other than a bad spindle drive. You need to Meg your motor if you keep blowing transistors.
Tags
fanuc 21tb, mori lathe, mori seiki cl 20, reverse
Problem- Did Mori Seiki Buy Hitachi Seiki? Billet Sean Mori lathes 6 05-04-2011 10:12 PM
Hitachi-Mori seiki spindle HG400 fabshop Mori Mills 2 05-18-2009 08:08 AM
Need Help!- Fanuc Spindle Motor erratic Mikecarter Machine Problems, Solutions , Wireless DNC, serial port 0 11-05-2008 01:22 PM
spindle belts for mori seiki mv35/40 brandou10l General Metal Working Machines 2 01-06-2008 05:59 AM
mori seiki mill with a spindle problem imwllc General Metal Working Machines 3 06-26-2005 06:31 PM
