Results 1 to 2 of 2
Thread: AL-20, fanuc OT, turret won't home, still
    May 2008
    us
    turret spins indefinitely. Replaced 2 bad prox switches. #1 index & turret clamp. From tool #1 home position, with home light on, switch set to #2 thru #8, turret will index to just before #3 position, hesitates, then rotates slightly, then seats... Will not index after (error). Will not home after reset. Book suggests gain adjustment.
    Home, turret clamp & count signals good at Control DGN's. Any/all ideas considered. Mori tech suggested that the turret contactor goes bad on this machine. Causing the turret deccel signal to fail. Which is the turret contactor?
    Does the turret clamp prox. switch have any effect on the indexing, or just clamp/unclamp?
    May 2010
    india
    Please check the encoder of the turret motor, it appears to be malfunctioning.
  1. Home made lathe turret
    By brucesu1 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-22-2009, 01:20 AM
  2. Help SL-20 turret will no home
    By CNCMAN 83 in forum Haas Lathes
    Last Post: 03-09-2009, 06:27 PM
  3. fanuc 21i double turret
    By nabil_elbadri in forum Fanuc
    Last Post: 01-12-2008, 12:08 AM
  4. Turret won't home upon startup, pls help
    By Millenium in forum Haas Lathes
    Last Post: 07-21-2007, 10:19 AM
  5. Fanuc 18i - KIA SKT250MS - Turret ?
    By Joey in forum Fanuc
    Last Post: 02-27-2007, 11:23 AM
