Page 3 of 3 FirstFirst 123
Results 25 to 29 of 29
Thread: mori turret spinning
  1. #25
    May 2008
    us
    Mori turret spinning
    One or more turret limit switches are bad, or need to be adjusted.
    Quote Originally Posted by angelmkt View Post
    hello to all.
    i have a problem with my Mori Mv-45 with Fanuc 6m control. in MDI mode i write T0001 command and magazine moves just one position in CW and if i write from T0002-T0010 command, it rotates in CW and it doesn't stop and if i write from T0011-T0020 it rotates in CCW and it doesn't stop until i press RESET boton. Also when i write M6 command cycle star light is on but nothing happens. do you know anything about this? any comment will be helpful.
  2. #26
    Apr 2011
    mexico
    thanks claya.
    i already check all limit switches and they are ok. right now i'm checking the circuit of my rotary transducer. have you ever checked this part?
  3. #27
    May 2008
    us
    Our machine only has limit switches. No rotary transducer. If the limit switch is much less than 24V then it is bad. I believe anything less than 22V is to low. Our switches measured around 16V.
  4. #28
    Apr 2011
    mexico
    yes, you're right about the voltage in limit switches, that's why i'm sure that my limit switches are ok because i got 23V. thanks anyway, i'll keep trying with the circuit of rotary transducer
  • #29
    Dec 2010
    canada
    tool ZERO
    T0002-T0010
    the turret should spin looking for tool ZERO
    you could use T0100 or T0200 the first two is the pocket and last 2 the offset
  • Page 3 of 3 FirstFirst 123
    1. Bridgeport Powerpath lathe turret spinning
      By Larry Callahan in forum General Metal Working Machines
      Last Post: 02-10-2010, 10:44 AM
    2. Mori SL3-H Turret alignment
      By JL Fabrication in forum Mori lathes
      Last Post: 07-23-2009, 09:26 PM
    3. Replies: 1
      Last Post: 01-11-2009, 04:10 PM
    4. Qt-10 turret spinning
      By laamar in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 10-03-2008, 04:49 PM
    5. Mori Seiki SL 0H turret
      By tapserv in forum Mori lathes
      Last Post: 01-20-2008, 02:01 PM
