| Mori lathes Discuss Mori lathes here. |
My CNC lathe doesn't work with the G71 code. Is there anyone who was able to use the G71 code successfully on MORI SEIKI SL-1A WITH YASNAC LX-1 control or can someone fix my program % O1234(0161-0414AAA) (DF.005R 11/23/2010, 7.30.32 PM) (MORI LATHE G71/G72 cycles) N10 G0 G40 G99 M08 G50 T5500 S1500 G97 S1500 M00 T505 M18 (BORE) G0 X0.2 Z0.013 X0.1314 G71 P100 Q105 U0 W0.003 D0.05 F.005 N100 G94 G1 X-4.4828 Z0.003 F.005 G3 X-4.4376 Z-0.019 I0 K-0.0226 G1 X-4.423 Z-0.437 X-2.8938 G3 X-2.7826 Z-0.492 I0 K-0.0556 G1 X-2.7578 Z-1.202 X0.0312 N105 G0 X0.1314 Z0.013 G70 P100 Q105 G0 X0.2312 Z-1.202 Z0 X0 G0 Z2. M09 G51 M05 M30 % |
| So, I tried the program and the 93 alarm error went off and i was unable to run the program. The G71 didn't work. It jumped to the N105 and the alarm started. If somebody was able to use the G71 on the Mori Secki lathe could you share a sample with me.Thanks |
| Alarm 093 is unusable G or M code in finish shape program (N100 to N105). As far as I can tell, there are NO M-codes, and only the G94 isn't "usable" in a Multiple Repetitive Cycle. |
"I'm not sure if this is your problem or not, but the manual states that the move in N100 must be parallel to X axis. You might try the following: N100 G0 X-4.4828 F.005 G1 Z0.003 G3 X-4.4376 Z-0.019 I0 K-0.0226" I looked over the G71 code and saw that I had made a mistake and that you where right. Thanks for your help. |
#10
| A trick I have been using for many years on that control Put a block skip "/" in front of the G71 and offset the tool back a safe distance Turn on block skip on your panel, run the routine at a safe distance off your work piece What this does, Will verify it the part program path works and take the guess work out of Canned cycle vs Code error. It only adds a few minutes to your set up time, but can save much time scratching your head trying to figure out exactly where problems are on new set ups Lucky, that LX1 control gives you more clues to problems than earlier versions on the alarm page One of my favorite errors is forgetting to follow a G2 move with a G1, After almost 30 years running these, I still sometimes forget to follow a radial move to a linear Wayne
__________________ http://nosala.com The Mori Seiki Underground Message Board |
| Need Help!- mori seiki al2 w/yasnak L3 work offset troubles | mkshrews | Mori lathes | 0 | 11-09-2010 01:44 PM |
| Need Help!- Mori Seiki Lathe Sl 3A | rajuicnc | Mori lathes | 25 | 09-27-2010 06:37 AM |
| Mori Seiki SL3 lathe | peckw | CNCzone Club House | 5 | 08-24-2010 01:44 AM |
| Cam for an old Mori Seiki lathe | Bob Shaw | General CAM Discussion | 1 | 02-28-2009 11:49 AM |
| Need Help!- Mori Seiki SL-403 Lathe | alc1960 | Mori lathes | 5 | 09-23-2008 09:35 AM |
