Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 10-26-2010, 03:05 PM
Prospot is on a distinguished road
mori SL-15 canned cycle
we have a mori Sl-15 w/Fanuc 10t control there is no option for G83
is there any way to use G74 and have full retract out of the hole?
or does anyone know what pram it is to turn on the option for G83
Thanks Sam
Old 10-26-2010, 05:02 PM
littlerob's Avatar
littlerob is on a distinguished road
It is an impossibility that the control won't support G83.
What is happening when you try to use it? Alarm? Sitting? What function are you trying to use it for? C axis drill or lathe drill?
The beaten path, is exclusively for beaten men.
Old 10-26-2010, 06:23 PM
dcoupar's Avatar
Why is it an impossibility? G83 was an option, and Mori didn't include it with the machines.
Old 10-26-2010, 06:29 PM
dcoupar's Avatar
Thanks Sam
The only parameter I can find for G74 is 6217 (Return amount). Could you do it with a coolant feeding drill?
Old 10-26-2010, 08:39 PM
littlerob's Avatar
HUH? No peck drilling? Sorry I was wrong.
Robert
http://www.cnczone.com/vb...cycles-152872/
Old 10-27-2010, 07:57 AM
chucker's Avatar
chucker is on a distinguished road
Drill Cycle
Here is a link to a custom macro drill cycle that could help you do the same thing.
CUTTING TOOL ENGINEERING Plus | Pecking Order
Old 10-27-2010, 10:17 AM
dcoupar's Avatar
Most of those old Mori's didn't have the Custom Macro option turned on either.
Old 11-02-2010, 11:44 AM
g-codeguy is on a distinguished road
But the good thing about being "old" is that they can be turned on. Not that I am advocating it. Fanuc needs to make money too!
Old 12-08-2010, 11:16 AM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
This is what I came up with for a full retract.
Hope it helps you in some way.
O00001 ( FANUC 10T)
N01 G18 G20 G40 G80 G90 G98
N02 G00 G28 U0. W0.
(JOB 1 DRILLING CYCLE )
N03 T0707
N04 M01
N05 G50 S400
N06 G97 M04
N07 G54 X0. Z.1 M08
N08 G97 S400
(DRILL FACE - G74)
N09 G74 X0. Z-3. I0. K.2 F.01
N10 G40
N11 Z5.
N13 T0700
N16 M09
N17 M05
N18 G28 U0. W0.
N19 M30
Old 12-08-2010, 03:10 PM
O00001 ( FANUC 10T)
N02 G00 G28 U0. W0.
N03 T0707
N04 M01
N05 G50 S400
N06 G97 M04
N07 G54 X0. Z.1 M08
N08 G97 S400
(DRILL FACE - G74)
N10 G40
N11 Z5.
N13 T0700
N16 M09
N17 M05
N18 G28 U0. W0.
N19 M30
See post #4 by Mr. Coupar. G74 is not a full retract cycle unless you want to change parameter 6217 for every drill cycle.
  #11   Ban this user!
Old 12-08-2010, 03:13 PM
Aye ...well I guess that param. is changed on my control, works for me Sorry.
  #12   Ban this user!
Old 12-08-2010, 06:00 PM
No need to apologize to me. If it works for you, then great. I'm not about to call you a liar. I don't know a tenth of what some of these guys know. What machine/control are you using? We have OT, 6T, 10T, 16TT, 18T & 21i-T controls on Hardinge, Mori, Daewoo, Takisawa, and Nakamura Tome lathes and it doesn't fully retract on any of them. How far does the tool clear the part on retraction? Is it always the same distance in front of the face? As I understand it, I would have to change that parameter for every drill cycle that used a different drill depth because it is a fixed amount.
I almost never use a G74 for anything other than a chip break cycle for face grooves. I use the deep drill cycle that comes in Hardinge lathes in all our Fanuc controlled lathes. Well...with a few personal modifications of my own.
EDIT: I notice you use a single block call. I assume your machine is an older one. All ours but one use the 2-block call. It is an older Mori Seiki. On 16i-/18i-TA controls the retract parameter for the G74 cycle is 5139. This is why it is critical to know your machine well before attempting to change any parameters. You could wind up in deep doodoo otherwise.
Mori MV 35 SteveY Mori Mills 0 10-21-2010 12:25 PM
Mori NL positiverake Mori lathes 4 12-16-2009 10:04 AM
Mori SL1 jkoper AjaxCNC Control Products 0 06-20-2009 03:13 PM
Mori w/10T grease Fanuc 2 10-26-2007 05:10 PM
mori dj stu Post Processor Files 3 03-17-2005 12:14 AM
