Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By dbstream
Thread: Mori Seiki Fanuc O-T Error EX357
    Sep 2006
    Hello again.
    I have a Mori Seiki SL-25B5 that gives me an error "EX357 Turret Index Time Up" whenever I try to index the turret.
    Any ideas?
    Thanks,
    Heath
    Feb 2009
    If the turret pops out, and doesn't rotate, probably the unclamp switch. If it rotates then goes back but times out, it could be the clamp switch. You really need to check the I/O signals and see whats not right. If the machine sat for a long time, my guess is it's a clamp switch not popping out with the turret. A little WD40 works well. Those early machines do eat Bestac Boards, which is a small relay card. They are pretty cheap.
    Sep 2006
    Well,
    the turret pops out. The error comes up as soon as you let go of the index button.
    The only switches I see on the turret are on the tail. One axial and several radial. They are are proximity switches.
    What are the addresses for the I/O's?
    Mar 2008
    SGP
    Check dgn21.2 for turret clamp fin. After turret pops out, dgn21.2 should turn to "0". If remains as "1", turret rotation is not possible. Proximity switch label as SQ14 or LS14 may be bad. Good Luck!
    Sep 2006
    Quote Originally Posted by dbstream View Post
    dgn21.2 does indicate that LS14 is working correctly. (changes state)
    Mar 2008
    SGP
    Check dgn48.4 for turret index start output which turn on bestact relay KR15(inside electrical cabinet) & solenoid valve YV81(mounted above index oil motor). Either KR17 & YV91 or KR18 & YV90 should turn on for rotational output.
    Sep 2006
    dbstream,
    On the bestact board, which ones are KR15, 17, and 18?
    I have no electrical prints.
    dgn48.4 does change.
    Mar 2008
    SGP
    KR15 is sixth "led" counting from the top. See attached
    Attached Thumbnails Attached Thumbnails Mori Seiki Fanuc O-T  Error EX357-circuit.pdf
    sujin likes this.
    Sep 2006
    Been a while but I am back on the Mori. 48.4 and KR15 both change state. KR17 & KR18 do not turn on at all.
    Does anyone know anything about timers in the parameter list?
    Feb 2009
    You need to check the physical output of the KR15. The led on the board is just the control voltage to turn on the relay. It's the relays that fail themselves. All timer descriptions are in the back of the ladder diagram.
    Sep 2006
    Well I got it.
    The timers where set to 00000000.
    Neet, huh?
    Thanks again for the help fellas! I appreciated it.
    Heath
    1. help MORI SEIKI MV- 40 FANUC MF-M4
      By vladimir1409 in forum Fanuc
      Last Post: 01-17-2013, 12:58 PM
    2. Mori Seiki SV 500 With FANUC controls
      By bfedger in forum Mori Mills
      Last Post: 02-14-2010, 06:59 PM
    3. Mori Seiki SL-20 Fanuc 10T
      By premier_industr in forum Fanuc
      Last Post: 12-15-2009, 08:55 AM
    4. Mori Seiki Lathe Error 414
      By KSDeerSlayer in forum Mori lathes
      Last Post: 09-19-2008, 08:33 PM
    5. Replies: 6
      Last Post: 03-20-2007, 10:54 AM
