Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 10-14-2010, 04:08 PM
hrhoward is on a distinguished road
Question Mori Seiki Fanuc O-T Alarm 100 p/s
Hello.
We just got a very nice looking Mori Seiki SL-25B5 with a Fanuc O-T control.
I have an Alarm 100 p/s.
I can zero out the X and Z and jog them around.
I have absolutely no documentation on this machine (serial number 3432).
How do I figure out what memory has been lost? (out of service for several years)
I might have a Fanuc O-T manual.
Any help would be appreciated.
Thanks,
Heath
Old 10-14-2010, 04:28 PM
Al_The_Man's Avatar
Alarm 100 is usually when the PWE 'Parameter Write Enable' bit is set, this can be confirmed on the 'Setting' screen.
This will usually put the machine into E-Stop!.
Do you have the parameters on the machine?
900 Options, user par. and diagnostic counter/timers in either hard or soft copy?
Old 10-14-2010, 04:32 PM
underthetire is on a distinguished road
It won't estop a Mori. You can even hit cancel and reset at the same time and the alarm will clear, allowing full operation of the machine.
Old 10-14-2010, 04:43 PM
Thanks for the replies fellas.
Al, I have no documentation on this lathe.
underthetire, I will give that a shot tomorrow morning.
Heath
Old 10-14-2010, 04:48 PM
You still will need to eventually turn off PWE in the settings page.
Old 10-14-2010, 05:33 PM
Al_The_Man's Avatar
If you P.M. me an email add I can help with the manual.
Old 10-15-2010, 12:46 PM
Will do Al.
I cleared the alarm. I can get the spindle and axis' to jog now.
Thanks!
I have a turret alarm now but I will start a new thread on that one.
Old 10-15-2010, 12:57 PM
Al_The_Man's Avatar
If you have the right 0T version you should be able to trouble shoot that with the on screen ladder display.
It is turned on by a user parameter if it is displayable.
P0060 bit #2.
Old 10-15-2010, 01:33 PM
Mori usually has a displayable ladder. Sometimes it asks for a password, type in "L" then hit input. Post the alarm and i can help.
Mori-Seiki SL-0 / Yasnac LX1 Alarm Code 332 Help!?! larrynsr Machine Problems, Solutions , Wireless DNC, serial port 2 07-25-2011 10:59 PM
Need Help!- Mori Seiki Fanuc 6M ALARM ERRORS HouTX Fanuc 5 12-02-2010 05:55 AM
SERVO ALARM 401 REPEATING IN MORI SEIKI CHANDRU Mori lathes 5 12-02-2010 05:36 AM
Need Help!- Memory alarm on Mori seiki lathe hectorbach Mori lathes 14 01-05-2010 06:04 PM
Mori Seiki SL-20 Fanuc 10T premier_industr Fanuc 7 12-15-2009 07:55 AM
