wow, AL2, that brings back some stories...
Anyway, there is a re-settable breaker in the drive. It has a pushbutton on it to re-set it. It's actually a contactor with an overload realy if I remember correctly, but whatever. Check that.
I am getting an Alarm Code "SV013 X Improper V-Ready Off". Book says Check for a 100vac between terminal 3 and 4. Check fuse breaker is not tripped. Can anyone help me out here...where are terminal 3 an4? Which fuse breaker and where is it? Also what next if I do or do not have 100 vac?
what do you mean "in the drive"? Where?
Electrical cabinet, X axis servo unit. You can also fry yourself if you don't know what you are doing, so be careful. Drives store energy for a while even if the power is off.
how do I tell what is the X axis servo unit? Sorry for the lack of knowledge.
