| Mori lathes Discuss Mori lathes here. |
I AM CURRENTLY WORKING ON THIS PART THAT REQUIRES A C AXIS SLOT AT THE FACE END OF THE PART USING Y,Z,C. I THINK THIS MAY BE CALLED A J-SLOT. I AM NOT ABLE TO POST THE DRAWING SO I WILL TRY TO DESCRIBE. I AM PROGRAMMING IT FOR A HITACHI-SIEKI HICELL. THE TOOL WILL BE A CROSS ENDMILL PERPINDICULAR TO Z. THE SLOT WILL START BY FEEDING IN Z TO A POSITION OF MINUS ONE INCH,THEN ROTATING C AXIS BY 30.0 DEGREES,THEN CREATING AN OVAL FEATURE AT THIS POINT,LARGER THAN THE WIDTH OF ENTRY PATH,ROTATING BACK C-30.0 AND FEEDING BACK OUT TO START POSITION.I WANT TO BE ABLE TO USE COMP.MY QUESTION IS, IS IT POSSIBLE TO USE Y,Z,AND C IN CUTTER COMPENSATION? |
| cutter comp help... | forsale78 | CNCzone Club House | 1 | 08-09-2010 01:32 PM |
| Cutter Comp | Farmers Machine | CamSoft Products | 6 | 11-18-2009 10:33 AM |
| M2 cutter comp help | nlh | Mazak, Mitsubishi, Mazatrol | 2 | 06-02-2009 11:59 AM |
| Newbie- Using cutter comp eia/iso on M2 | apylus444 | Mazak, Mitsubishi, Mazatrol | 8 | 10-09-2008 08:44 PM |
| Cutter comp on an id hole< cutter diam.?? | PaintItBlue | Haas Mills | 5 | 05-05-2008 06:30 PM |
