Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 08-23-2010, 06:36 PM
dimatec is on a distinguished road
Unhappy NT4250 Tool Pre-Setter alarm
After adjusting x and z value for turret#2, I have EX1992 alarm every time I install tool presetter and also the PST button doesn't work too. When I remove the arm alarm goes off.
Any help? Thnx
Old 09-07-2010, 12:07 PM
matty555 is on a distinguished road
Hi
How much did you adjust it by and have you tried putting the old values back in?
Matty
Old 09-07-2010, 12:20 PM
underthetire is on a distinguished road
So I would assume this is a removable presetter. If there is no alarm with the cap on, but it alarms with the arm in, I would assume either the contacts are not mating up with the mount correctly, or the head went bad in the arm. If the machine does not see the correct signal from the arm, it will not go to PSM mode.
PS, I have seen the contact pins on the arm/mount actually broken off, check there first.
Tool Pre Setter Allen123 Mach Software (ArtSoft software) 0 03-15-2009 11:29 PM
Need Help!- Tool Setter Macro for M-V60C and Metrol Setter mitshack Mazak, Mitsubishi, Mazatrol 0 10-06-2008 08:39 AM
Need Help!- Tool setter macro for M-V60C and Metrol setter mitshack General CNC (Mill and Lathe) Control Software (NC) 0 10-06-2008 08:38 AM
Tool setter alarm Nine Blue Mazak, Mitsubishi, Mazatrol 3 02-17-2007 06:00 PM
tool setter ACME General Metalwork Discussion 8 07-30-2005 11:15 AM
