Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 08-17-2010, 08:07 AM
cnyttbircan is on a distinguished road
mori seiki FL-2 problem
Hello all;
Our Machine is Moriseiki FL-2 model 1998
Our main unit is fanuc 21-tb
I want to explain our problem
firstly machine gave servo alarm because of electric problem. Then we bought servo amplifier module from fanuc moscow. And also we controlled spindle amplifier module and power supply module in different moriseiki fl-2 machine and we saw that the spindle amplifier module and power supply module is also working fine...
So now we can say that our servo,spindle and power supply module is working fine... But when we power on our machine the machine doesn`t give alarm first. but if I want to use handle jog; i see that x and z axis doesn`t move. And also if I want to cw spindle; I see that spindle doesn`t turn properly... if I continue use handle jog; alarm 410 accured on the screen. And also if I continue cw spindle;alarm 750 accured on the screen...
Yesterday I disconnect x axis motor from X axis mill and I opened the machine again... And I saw that motor doesn`t turn with handle jog...
Anyone have an idea about my problem?
My Best Regards
Cuneyt Bircan
Old 08-17-2010, 08:50 AM
hitachibos is on a distinguished road
other than the normal KEY on the control fro memory /edit lock is there another key for "set-up" manual" auto" they started adding this key right around the late 90's
also have you tried closing the doors then joging it?
a 410 alarm is usually a mechanical binding more than a true voltage or current issue. did you just get this machine into your building? could there be some shipping bracket still on?
if you take off the way covers can you reach in and move the ball screws by hand?
Old 08-17-2010, 09:48 AM
underthetire is on a distinguished road
Sounds like a defective power supply module for the amplifiers. Swap the power amp from the other machine. An interlock such as a door switch will not give that alarm.
Need Help!- Mori Seiki SL-65 tailstock problem brad63av Mori lathes 3 10-07-2009 10:36 PM
Need Help!- problem in MORI SEIKI SL-0 metoaly Machine Problems, Solutions , Wireless DNC, serial port 0 10-07-2009 01:03 PM
Threading problem on Mori seiki zl-15smc DryRun G-Code Programing 4 09-19-2007 11:57 AM
Mori Seiki ZL-15 Startup problem??? =ego= General Electronics Discussion 11 06-26-2007 03:07 PM
mori seiki mill with a spindle problem imwllc General Metal Working Machines 3 06-26-2005 06:31 PM
