Results 1 to 6 of 6
Thread: NL 3000 Peck Drilling
    Oct 2008
    We just bought a new NL 3000, and I'm a mill guy trying to convert to run this lathe. My object is pretty simple, I just want to peck drill with a full retract when it pecks. G83 with a Q and a R does it on the mill, but doesn't on the lathe. What am I missing?
    Thanks for any help!
    Apr 2010
    Are you running a live tool or static if your running static in the detail page there is step amount and theres like a cut depth before retract so if your step is .500 and your peck is .050 then its going to peck to.500 i have to look at my machine tomorrow about retracting out when running live i can't remember with out looking at the detail page
    Oct 2008
    No live tooling. I figured out the peck amount, I just can't figure out how to set a retract point with a canned cycle. To get by for now I just manually programmed it move by move.
    May 2007
    What control? I have what you need if it is a Fanuc control, and you have Macro B.
    Aug 2010
    you want to use a face groving cycle without any "X" move in it.
    if you need more explanation let me know.
    May 2007
    G74 is a drill (face groove) pecking cycle. Tool will only withdraw an amount set in a parameter. It will not fully retract as the OP wants. Lathes I am familiar with only use G83 for live tooling. There are a ton I'm not familiar with.
    1. Need Help!- peck drilling?
      By Tristar500 in forum BobCad-Cam
      Last Post: 01-20-2010, 02:25 PM
    2. Peck Drilling Help
      By soonervols in forum G-Code Programing
      Last Post: 06-09-2008, 07:26 AM
    3. Need Help!- v22 peck drilling
      By 68sixspeed in forum BobCad-Cam
      Last Post: 04-03-2008, 05:17 PM
    4. Peck Drilling
      By RBrandes in forum Haas Mills
      Last Post: 06-18-2007, 08:03 PM
    5. Peck drilling
      By LarryMiran in forum Carken Products (Deskam, DeskCNC etc)
      Last Post: 10-23-2004, 06:12 PM
