Results 1 to 3 of 3
Thread: Mori Seiki Lathe SL35 Q-setter
    Feb 2010
    Good day. I have an SL35 that I'm having a problem with the Q-setter. Normally when I put the arm down, the page automatically opens to the setting page. It doesn't do it anymore. Not only that, when I push the pb to go to the Q-setter page, it doesn't display the proper tool that's in place, for measurement. I'am also getting a "WSFT" flashing in the lower left hand corner of the screen. We bought this machine used, a long time ago, and it came with no books so I have no information to study. Thank you for your help.
    Aug 2008
    There is a limit switch that reads when the arm is up. It is located in the slot where the latching mechanism goes into. It may be stuck and still thinks the arm is up. Spray some WD on it to loosen it up, or it may be damaged. Seen the problem on a SL-15 a couple of days ago.
    Feb 2010
    Thanks, I'll give it a check.
  1. Need Help!- Mori Seiki Lathe Sl 3A
    By rajuicnc in forum Mori lathes
    Last Post: 09-27-2010, 07:37 AM
  2. Need Help!- mori seiki SL-3A lathe w/fanuc 6
    By enrique flores in forum Mori lathes
    Last Post: 07-16-2009, 05:24 PM
  3. Cam for an old Mori Seiki lathe
    By Bob Shaw in forum General CAM Discussion
    Last Post: 02-28-2009, 12:49 PM
  4. Need Help!- Mori Seiki SL-403 Lathe
    By alc1960 in forum Mori lathes
    Last Post: 09-23-2008, 10:35 AM
  5. nam sun lathe/mori seiki knock off
    By jheyliger in forum General Metal Working Machines
    Last Post: 04-27-2008, 02:42 PM
