| Mori lathes Discuss Mori lathes here. |
Hello, I am a swiss programmer and I don't know a thing about Mori Lathes. I want to try to program a thread mill on a Mori SL-25m. This machine does not have "Y" axis. So I would like to see if anybody out there knows if I can use "X,Z & C" to do so. I have done it on a L20 citizen machine. This Mori SL-25m is about 10 years old. I was wondering if anybody out there has done it and if so if they can please help me out by pointing me on the right direction. Thank you. |
| Absolutely yes, even if the machine wouldn't support it (I would be very surprised if it doesn't) you could find the toolpath and post out tiny incremental moves. UTT will correct me if I'm wrong.
__________________ The beaten path, is exclusively for beaten men. |
| Ok, so it's a 20 year old machine, if it's green it's older still. It may or may not be able to, the very first ones had either C axis position only, or optional C axis contour control. First you need to command C axis mode and see if it will feed positions, or just index to positions. |
| first thing you'll want to do is enable the C axis and try to do a G1 move with Z and C at the same time to see if you have C axis contour or position only. I'm going to use a program technique from the newer model machines as i'm not 100% familiar with the programming on such a vintage machine ![]() M69(SPINDLE UNCLAMP) M45(MILLING MODE) G28H0 (HOME C AXIS) G1G98H360W1.F5000. (MOVE C 360 DEGREES AND Z 1.0 INCREMENTALLY AT A FEED OF 5000 DEGREES PER MNUTE) if that test passes, you have a contouring C and can continue forward. if it's a center hole, you can just simply position X to the center of the hole, do a linear move and turn on cutter comp to the diameter you wish to machine, rotate c and move z at the same time (H360 or -360. W = the pitch you wish to machine i.e. for 1/4-20 W.0555 or -.0555 depending on if you want to machine out of the hole or into the hole from current position. example: M45 G28H0 G0T101 S2000M13 Z.25 X0M8 G1G41G98X.25F10. H360.W.0555F2000. G40X0F10. G0Z.25 M5 M9 M1 if it's an off center hole, use polar interpolation (g112/g12.1) and program it in the same manner as X/Y movements remembering that polar interpolation automatically converts degrees per minute into inches per minute. |
Have you try?
__________________ The best way to learn is trial error. |
| Index to "Epoxy-Granite machine bases" thread | walter | Epoxy Granite | 13 | 12-01-2011 10:45 PM |
| Weight of "Bridgeport Series II Interact 2" milling machine | ichudov | Bridgeport and Hardinge Mills | 3 | 03-23-2010 04:21 PM |
| Newbie- First Machine HELP...24"x36"x4" or Larger Setup w/ Gecko for under $3000 | buschhoff | Want To Buy...Need help! | 4 | 03-20-2010 06:37 PM |
| Need Help!- "motor steps per resolution" and "driver microstepping" settings | margni74 | LinuxCNC (formerly EMC2) | 9 | 10-24-2009 02:33 AM |
| "J" head type "millport"(tiwan,1980) clutch | marksbug | Bridgeport and Hardinge Mills | 1 | 08-17-2009 10:48 AM |
