Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 06-10-2010, 11:51 PM
Fear is on a distinguished road
Arrow SL-4 Voltage required
Does anyone know how much power you need to run this machine properly?
-MG
Old 06-11-2010, 12:02 AM
jaherrera3499 is on a distinguished road
220V A/C +/- 10%
198V-242V
You need to check your motor ratings to see what KVa's are needed.
There was once the power rating that the machine required stamped on the label that has the machine model and serial number, next to the main power switch.
Old 06-11-2010, 12:15 AM
Thank you!
Help required please powely General Metalwork Discussion 7 04-05-2010 03:36 AM
Newbie- Help required Summer5 G-Code Programing 9 02-10-2010 04:50 AM
help required willheg Stepper Motors and Drives 3 12-14-2009 04:41 PM
G320/G340 'Required Direction Setup' and 'Required Direction Hold' times? margni74 Gecko Drives 2 12-05-2008 08:10 PM
Help..Stuck at relay ext dc voltage missing but dc voltage OK ? Dirky Bridgeport and Hardinge Mills 24 11-27-2007 07:33 AM
