Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 05-01-2010, 10:33 PM
3snc is on a distinguished road
Mori Seiki SL-15 1989 X axis Ball Screw
Need help with a Mori Seiki SL-15 1989 (x axis ball screw)
Trying to take the x axis ball screw out and having trouble. I don't have a manual and can't figure it out.
The thrust bearings are out and the nut is loose but the screw will not pull out of the support bearing. Removed everthing with out taking the turret off but can not understand what would keep the screw from pulling out. If anyone has ever done this or has a manual please let me know. 3s.farrell@gmail.com
Old 05-03-2010, 11:53 AM
Txmaint is on a distinguished road
You need to remove the ball nut from the cross slide. It should be held on with several bolts and taper pins/ keyed insert.
Old 05-03-2010, 01:55 PM
underthetire is on a distinguished road
I agree. Some machines you can unbolt the block without removing the turret, others you need to lift the turret off the cross slide. Last one I did the 4 bolts were right behind the turret on the slide. A "M" machine may not have enough room.
Ex Mori Seiki Application Engineer (multi-axis specialist) the thrill Employment Opportunity 1 11-21-2011 11:38 AM
Z axis ball screw dgapilot Shopmaster/Shoptask 18 08-14-2009 05:20 PM
Turning a Chess Rook on a Mori Seiki Y-axis Lathe Glacern Videos 0 07-29-2009 05:23 AM
Build Thread- Mori SL-00 X axis Ball Screw mrchang Mori lathes 3 03-02-2009 04:20 PM
Mori Seiki Z axis Thrust Bearing TWyatt9 General Metal Working Machines 0 08-15-2007 09:25 AM
