| Mori lathes Discuss Mori lathes here. |
Hello, We just got a new NL2000Y. It's our first Y-axis machine and I have never used this type of lathe before. I have a dual od turning tool holder and there doesn't seem to be a way to enter the tool geometry offset for the Y-axis using the tool presetter.I am assuming this has to be done manually, or am I missing something? Thanks in advance. |
| Yes you do have to manually enter the y position in tool geometry page the upper tool you would put a -1.750 for example. When using dual turning tools you have to Manually edit the tool call in code usually its G0 T0606 it needs to programed as G0 T0606 Y0 you have to add the Y0 after you translate to code |
| We have an NLY and had the same issue. There are parameters that will allow you to use the pre-setter when you have the Y axis off zero. You would have to contact Mori support (usually from the company you bought the machine from) to get them. We use a quad holder all the time and use the presetter for setting x and z. To do this you have to manually dial your turret to the correct Y location. Once the X and Z are set you can put the Y offset in manually. They may not want to give you the parameters yet until you've had some time to get used to the machine though. Now, from the programming side, you have to move the turret to a safe x position and then call your Y zero or else you will alarm out. Same thing on the way home, You must home the Y axis prior to going home in the X. I can do a program example if you need it. Gunner
__________________ Gunner |
the trick with quad holders is setting them up so you can use the presetter example using a w- insert rough and a v-insert finisher w insert tool on the bottom stubbed as much as practical v insert tool on top hanging out past the lower tool enough so that when you use the presetter the lower tool doesnt hit the presetter arm this setup works on bar stock applications, if your doing large chuck work you might have to set the tools equally note: if you use your quad holder to profile chuck jaws for clearance you have to use the bottom pocket due to limited y travel at the upper x values |
| Need Help!- How to measure correct tool offset specially in X axis for a DRILL in CNC LATHE | TS ENGG | Calibration & Measurement | 1 | 04-10-2010 02:24 AM |
| Need Help!- Okuma howa tool geometry protect | chrisclegg | Okuma | 0 | 10-10-2008 08:36 AM |
| Loading tool geometry with G10 ??? | theemudracer | Fanuc | 10 | 12-10-2007 07:06 PM |
| Lathe geometry offset | cncdigger | General CNC (Mill and Lathe) Control Software (NC) | 2 | 01-29-2007 04:52 PM |
| Help needed on tool path geometry | 2_jammer | G-Code Programing | 23 | 03-12-2006 11:03 PM |
