Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Mori lathes
Mori lathes Discuss Mori lathes here.
Old 03-09-2010, 01:25 PM
JL Fabrication is on a distinguished road
Help with Acme threading on SL3H
I am hoping someone can help me with a programing/ threading problem. I have a mori SL3H with LX-1 Control
I am threading 5/8" 7 pitch acme thread which is a non standard thread. I have everything worked out fine except the termination point of the threads. In the picture you can see I end up with a razor sharp thread as the last thread.
In the second picture is a sample part which I would prefer where the tread terminates as a full thread.
How do I go about doing this??
Name:	Valve stems 004.jpg‎
ID:	102430   Click image for larger version
Name:	Valve stems 007.jpg‎
Old 03-18-2010, 05:11 PM
ken70ss396@yaho is on a distinguished road
Thumbs up
In the first example you can see a chamfer pullout at the end of the thread.
Are you using a G76 cycle? If so, on the first G76 line you will have a P followed by number of values. Example G76 P010060. The first 01 represents the number of spring passes.
The next 00 represents the chamfer amount pullout. 00 equals a straight pullout. To calculate the chamfer amount of pullout, multiply the two digit value(example 05 instead of 00), by the thread pitch. Example P010560=05 x .111= .0556 chamfer length.
The 06 is the thread angle.
The line would finish with Q0050 = minimum depth of pass, no decimal point . Then R0.0005 =depth of last thread pass.
G76 P010560 Q0050 R0.0005 .
For your part you may need to try 10 to replace the 00, for full thread pitch pullout amount. You may also need to decrease the z length by 1x thread pitch.
Old 03-18-2010, 06:38 PM
Thanks for the reply I will give it a try in a few days. My lathe is down at the moment I had one of the drive cards go bad. Hopefully I will get it up and going soon.
Jason
Need Help!- Threading double lead acme bmwfund Diemaking and Diecutting 4 06-04-2009 05:26 PM
Acme threading fishinchip999 General Metalwork Discussion 8 03-31-2009 08:44 PM
Need Help!- Acme Threading ndp Machine Problems, Solutions , Wireless DNC, serial port 3 02-02-2009 11:27 AM
3 Pitch Acme Threading Help metx General Metalwork Discussion 5 02-02-2009 07:30 AM
ID Acme threading tool needed 2_jammer General Metalwork Discussion 2 04-18-2005 09:08 PM
