Originally Posted by
Custom Billet
Hey Harri,
I may be able to help you on this one. I haven't tried it, but it is interesting.
Have you ever had your machine get stuck in single block? This is what happened when I first got my TV-30. I called Mori, they said I needed to replace the touch screen. It's only about 3G's! After calling back a few times, I got a hold of the right guy. I just had to clear the GOP parameters. They sent me the procedure.
Here is where it got interesting......I put in the codes, and restarted the machine. When it fired back up, it was in Japanese! I kinda freaked out. Anyway, I called Mori back and finally got a hold of the right person again that had hand written notes on how to fix it if it popped up in a different language. Whew, back to English again!
Anyway, it changed a few things. The "MEM" button changed to "Auto". Then it added a button that is not in the manual. It is on the far top right and says RES I think. I'll check later. It has arrows going around the outside in a clockwise direction. That may be the DNC button???
I haven't had time to try it though. Just a thought. After reading your post, I am thinking that the DNC was an option you had to pay for. I was told that when you put the GOP parameters in, in this order, it was some sort of password.
If you want, I will send you the procedure, but use it at your own risk!
Let me know.
Jim
