Mori Seiki TV-30 MSC-802M (M50) interpolation problems - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
Thread: Mori Seiki TV-30 MSC-802M (M50) interpolation problems
  1. #41
    Jan 2009
    That is NON-OP mode. The E-stop is in, or the air pressure is low. One of my machines has the air pressure alarm and the other does not, or it was bypasses by the previous owner. Check those two things out and if you are still stuck, let me know.
    Jim
  2. #42
    Nov 2010
    Doh!
    E-STOP was in because I had pressed it. LOL
  3. #43
    Jan 2009
    HA HA, yeah, sometimes that happens!
  4. #44
    Jan 2009
    Making parts?
  5. #45
    Registered RAJMENON's Avatar
    Nov 2012
    India
    How to restore mitsubishi MSC 802M mori seiki tv30
  6. #46
    Jul 2010
    india
    Default Re: Mori Seiki TV-400 with MSC-802M (M50) Manuals required
    Dear All
    Request You to kindly help me.
    I am working with Mori Seiki TV-400 with MSC-50M control for my friend.
    Need Operation manuals for read & run machine.
    if possible kindly share APC operation manual also.
    His mail ID :- cncmainte@gmail.com
    thanks
  7. #47
    Member moghul's Avatar
    Apr 2006
    PAKISTAN
    Default Re: Mori Seiki TV-30 MSC-802M (M50) interpolation problems
    hi all
    i have machine TV30 with MSC-802. all good but all axis going in positive direction. when i move in -ve the error. M01 operation error 0007.
    any one can help me here?
    what is the procedure of absolute zero setting?
    thanks all
  8. #48
    Nov 2010
    Hi Moghal,
    Piece of cake.
    My email is chrisclub@gmail.com
    X zero is far left, Y zero is far front.
    You can maximize your X and Y travel if you put it there manually with the power off before zeroing.
    Turn off power, take off the front cover and the back cover
    Push the table to the far left, but just before the X limit switch wheel is depressed.
    Move the Y to the far front but just before the limit switch is depressed.
    You will need a flashlight to see the Y limit switch wheel before it gets depressed.
    Then it is simple... turn on the power,
    Turn off the GOP keys,
    Press DGN/IN Out, ABS-SRV, Menu, Down arrow once. The [ABS Position Set] screen should be displayed.
    Type "1" in the X and Y positions.
    #(0) ( 1) (1 ) ( ) ( ), Input " Origin Set" is displayed
    #(1) (1 ) (1 ) ( ) ( ), Input "ORIG-RTN" is displayed
    Change the scale to x10, X axis, Handle mode, and rotate the jog wheel CCW until "OK" is displayed for X
    (You may have to hold in the Yellow Over Travel button behind the door on the right side of the control panel while jogging.)
    Then jog the Y axis until it says "OK".
    Zeroing Z is a little trickier. Send me an email if Z is also "NG".
    After power cycle, it should come up fine.
    But the problem is probably you need to change the 4 batteries in your Battery box in the back.
    Chris
  9. #49
    Nov 2013
    Dear Sir,
    Could u post me or PM Macro program for ATC and APC (9001,9002 and 9003)
    Many thanks in advance and best regards..
