- Problem- Mori seiki/ FANUC 10M problem...
Got some trouble when I last tried to download some Gcode. Ended with some file integrity error and all the parameters disappeared.
System parameters restored but the PMCpart seem to have some errors in it's data field definitions, believe I made a copy a little bit too late...
The machine gives no system errors but spindle refuse to rotate faster than about 1 turn/second and it does so in an akward way, might depend on some other factor.
G-code given in MDI-mode: S1000 M3;
If anybody have access to a mori seiki junior FANUC 10M I would appreciate a screen copy of this:
Just push the nc/pc button then soft buttons PCPRM and then DATA and you have your version of the page.
Does it look different? How much? Send the page to me!
My Hardware setup looks like this, (probably affects the data fields):
FANUC 10M version 1010C/F
Motherboard: A16B-101-0040/04C
Spindle Motor: FANUC AC Model 3
I/O card A16B-1210-0321 D1/D0 2 80/56
AC Spindle motor drive: - A16B-1100-0080
X/Y Drives: - A16B-1200-0230 dual DC drivers
Z: - A20B-0009-0320 single DC Driver
/Roger
- You may not post replies
- You may not edit your posts
Forum Rules
