Need Help! Rotary Tool Spindle
Results 1 to 2 of 2
Thread: Rotary Tool Spindle
    Oct 2015
    Default Rotary Tool Spindle
    I removedthe milling motor and sent it out for repair, there is a lot of work backed upon this machine and it’s all turning work, I just wanted to see if anyone has ever turned a NLX into a lathe after the milling motor has beenremoved, currently, the machine is operational because I bypassed the millingamp and turned off a couple of spindle parameters, but my problem is that when I index a tool, the turret unclamps and the logic islooking for a milling motor orient signal before it will index, could anyone helpme out, or is it impossible to run as a lathe, no one has an answer for me, I have talked to DMG MORI and MEAU with no answer as to how to make it work..
    NLX2500Y/700
    MSX 850
    Sep 2008
    Default Re: Rotary Tool Spindle
    Did you try looking for the orientation signal in the ladder diagram? If you can find that, there's probably a keep relay or data parameter you could change to trick the machine into thinking it doesn't have the live tooling option.
    The back of the Mori ladder diagrams have the keep relays and data parameters listed.
Rotary Tool Spindle
Rotary Tool Spindle
