Need Help! MORI SEIKI NHX5000
Results 1 to 3 of 3
Thread: MORI SEIKI NHX5000
    Sep 2017
    Slovenia
    Default MORI SEIKI NHX5000
    Hello to all...
    Does any know, how to edit PLC LADDER directly on machine, or witch program can be used for modify PLC.
    Controler on machone is Mitsubishi M730MB.
    I need to change one output signal (Y) to some difrent output signal.
    Reason: on I/O bord is brokem Y signal and new I/O is too much money to spend. This Y signal is from coolant pump for chip flud coolant under B axis.
    Thank you all for your help or sugestions how to fix the problem...
    BR...
    Sep 2017
    Bahrain
    Default Re: MORI SEIKI NHX5000
    Mori Seiki has locked the ladder for onboard editing. You may download through GX developer, modify and then restore
    Member Kenbeck's Avatar
    Dec 2022
    Quote Originally Posted by Igor1976P View Post
    Hello to all...
    BR...
    Send me Yr program and I will edit it for you, use kenbeckingham@btinternet.com
MORI SEIKI NHX5000
MORI SEIKI NHX5000
