- Need Help!- NH4000 Error - DS0059 Specified Number Not found
Hello all,
I am new to the CNC world, and I am currently having a problem with a NH4000 Mori Seiki Mill.
I am trying to call a work number from an external PLC (work no. 1000 and 3000) and I keep running into the error "DS0059 Specified Number Not Found".
The PLC is communicating with the Mill Via Ethernet IP where the Mill is configured as an Adapter, while the PLC is configured as a Scanner.
The PLC is currently able to communicate command such as Door Open/Close, Fixture Clamp/Unclamp, Index Pallet (0, 90, 180, 270) etc.
In the I/O mapping screen, it appears that the Mill is reading in the Proper Binary Bits for each specified Work Number. However, the error occurs each time the Set Up Lamp has been turned on, the Mill has issued an M30 command, and the APC Cycle has initiated.
I have check the D and R values in the Setting screen (95) and they all appear to have the correct binary values as well.
I was wondering if anyone else has come across this problem, and if so, how was it resolved?
-Scott
- You may not post replies
- You may not edit your posts
Forum Rules
