- Need Help!- DMG 85 mori monoblock Cycle 800 + Traori
Hi.
I was wondering is it possible to combine cycle 800 with Traori?. The reason i want to do this is for example i have a square part and just want to chuck it in a vice, then use the manual measure cycles to align the work piece face and an edge as well. This info is stored in G54 table and is all tied to the the cycle 800, now when i use a Traori cycle to do simultaneous 5 axis milling i want it to take into account the orientation correction from the values i got when using the manual cycles to align part.
Can someone show me a basic snip of code if this is possible?.
- You may not post replies
- You may not edit your posts
Forum Rules
