- DMG 85 Mori monoblock probe alarm when doing manual measure
Hi.
I am new to this machine and no one at work seems to know how to solve the problem. I am using a DMG MORI ERGOline Control
with Siemens 840D , its a five axis with a tilting table. Sometimes when i position the the probe manually to do a probing cycle i sometimes accidentally touch the job, the probe alarms out and the entire machine cannot be moved i tried the reset button and clear alarms but the alarm just stays there. The only solution is to take out the batteries out the probe and then i can move it away using the hand wheel. Is there any way to clear this alarm without taking out the batteries?.
Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
