Need Help! x shift Mori Seiki JR mill
Results 1 to 6 of 6
Thread: x shift Mori Seiki JR mill
    Aug 2008
    CANADA
    Default x shift Mori Seiki JR mill
    hi
    i got a Mori Seiki JR mill
    just recently i got out of the blue x shifts that happen randomly
    some days i get nothing all works well then without any reason the x axes shifts by about .01"
    not so critical when i do the first side of a part but when i work on the second side the shift will create scrap parts
    also what i noticed is
    when the shift happens and i send the machine home in x i get an over travel alarm which persists even when i try multiple times
    but when i shut the machine down and do a restart it finds the home no problem
    any ideas
    Mar 2017
    Default Re: x shift Mori Seiki JR mill
    I have had this problem on a machine that had a combination of fanuc ac servos and glass scales. The ref return dog was set improperly, causing it to jump grid. This would happen only on startup and it would jump the marker pulse with, about .125 . On a machine without scales and during operation I think it points to a bad pulsecoder.
    Aug 2008
    CANADA
    thanks
    will look into that pulse-coder
    do you know if they are repairable?
    Mar 2017
    replaceable yes. repairable, meh
    I have successfully replaced fanuc yellow cap motor encoders with these. I will get the exact item number I bought and post it Optical Rotary Encoders | AutomationDirect
    Mar 2017
    Here is the one I used along with a pinout of something. Its been too long. I had to make two adapter parts. One for the flange and one for the shaft. nothing major.
    Aug 2008
    CANADA
    thanks
