- NHX-6300 Parameters?
I would like a how to change and a list of parameters, like you get with the Fanuc parameter manual, that you don't get with a MORI.
I need to change the offset download so its in inches and not in millimeters.
I also need to access either grid shift or where ever they have the variables for the Mori probe sequence calibration info.
I have a Y axis error of .0007 or so that can not be changed by using the calibration sequence or even trying to fool the sequence with a work offset shift.
- You may not post replies
- You may not edit your posts
Forum Rules
