- MSC-802 m (MELDAS 50) parameter change
Dear all,
I know the #1043 parameter should change to 1 for English language.
But I don't know how to change a parameter on this machine.
I know I should unlock the parameters and I could do backup by serial port.
Thank you for your help.
Re: MSC-802 m (MELDAS 50) parameter change
Finally I discovered! how to access to machine parameters.
First of all you should unlock parameters on GOP page by pushing(touching) GOP soft key and pushing KEY schematic soft key.
Then you should push OFFSET soft key twice (two times).then press MENU soft key . Now you can access to SETUP soft key. By pushing it you can push PARAMETER soft key.
You should answer "Y" to access to Parameters.
Now you can select type of parameters by soft keys and scroll up and down by page up and page down key (on key broad) .
After changing of parameters you should turn off and then turn on the machine to activate parameter.
- You may not post replies
- You may not edit your posts
Forum Rules
