Manual mode, door unlock button. All other doors have to be closed. Easier to load through the spindle.
When I run OKK 550 Vertical Mill, I can set up tools for the next job by calling old tools and changing new tools at its side door.
But I can not open the side door and rotate tool change magazine in Mori Seiki NV5000. It takes along time for me when setting up new job.
Can anyone show me how to do this?
Thank you.
I tried last night already and could not do it.
Machine was running a program in TAPE Mode and whenever I tried to hit or activate other buttons, it stopped right after that.
Is there any other way to try, sir ?
It WILL NOT open while the machine is running, tape mode or otherwise.
Like I said, you can not open that door while the machine is running.
Actually, in some jobs, a cycle time is very short while setting up requires long time. I have to wait.
Thank you.
Odd, on the horizontals you can. It's just wont let you open during a tool change, I usually hit cycle stop while a cutters out of the parts and open'er up.
You must hit the manual button, wait for it to light up. You can't rotate the mag when the door is open, so you would hit manual, wait for the light, get to the pot you need, open door.
If you have a tool breakage detector, It might get picky. Don't do anything while the probe cycles.
The horizontals have a waiting pot.
Oddly, They made that door for what while it is not used ???
Does anyone think so?
