Mori Seiki SH 5000 not moves any axis
Results 1 to 10 of 10
Thread: Mori Seiki SH 5000 not moves any axis
    Mar 2013
    Estonia
    Default Mori Seiki SH 5000 not moves any axis
    Hi for all!
    Problem:
    Mori Seiki SH 5000/40 with Fanuc 18i/MSG-501 control. (APC with 2 palets)
    When turning on machine, system is booting and after massege "Open and close the door" when I open and closed the door turning on power for servo amps ATC and APC (SVU-20), in some seconds turning off it and after that turning on it again excepting APC servo amp.
    Not any alarm or massage after that and not any movement.
    Is there anybody who can explain me what may be the cause of this behavior?
    Thanks in advance!
    May 2013
    India
    See the Interlocks in ladder
    Feb 2009
    APC servo amp won't show much until time for pallet change. Check the MPG and make sure it's snapped in to the holder tight.
    Mar 2013
    Estonia
    I have Servo alarm (APC) EX1664 (319).
    And in manual operation do not rotating palet changer.
    I am working with Mori Seiki the first time and know not so much about it.
    So I need help very much.
    May 2013
    India
    The EX stands for External Alarm ( you can see the Details in ladder ) , Might be Check the Field Components / Fittings like , Air pressure / Proximity / Limits / Adjustments etc..
    Feb 2009
    You will need to go to the PMM (power Motion Manager) and see what alarm is on the Beta power mate controller. Most likely a dead battery and need zero return.
  7. #7
    Mar 2013
    Estonia
    Thanks for advices to all. It needs to set zero points so I am looking for Zero Point Adjustment SH5000-8000 instruction.
  8. #8
    Dec 2013
    Default Re: Mori Seiki SH 5000 not moves any axis
    Quote Originally Posted by coldrex View Post
    Hello Coldrex,
    Did you find the procedure for pallet changer zero point setting ?
    I'm having same error EX1664(319) with a SH4000 with 2 pallet changer with fanuc beta amplifier after replacing amplifier's fan.
  9. #9
    Oct 2007
    united states
    Both codrex and Cabron, Have you gotten the problems fixed? Did you get the home procedures? If not please let me know
  10. #10
    Dec 2013
    Quote Originally Posted by jp41558 View Post
    Hello,
    Yes I got it fixed thanks to procedure sent in by DMG MORI.
  11. #11
    Member antoniomasat's Avatar
    Feb 2016
    Torreon
    Quote Originally Posted by Cabron View Post
    Hello,
    Hello! Could you send me these procedure, please?
