The lathe in question is Mori Seiki SL-303 with MSG-501 controller;
We'd like to set the value of X WEAR of a tool to 30.000 but it turns out the value cannot be greater than 10.000 - any value over this causes "DATA IS OUT OF RANGE"-alarm.
Are the ranges of the tool offset wear values limited by a parameter, and if they are, which one?
(We got around this problem by adding the 30.000 directly to X GEOM, but we'd rather set it to X WEAR, as this style seems a lot safer in the long run.)
