- Need Help!- Setting workpiece zero with G10
The lathe in question is Mori Seiki SL-303 with MSG-501 controller:
We're trying to set the workpiece zero with G10 like this:
G10 L2 P1 Z-100.
This should set the Z value of G54 to -100. but it doesn't, nothing changes. But it doesn't cause an alarm either... so what's happening here?
Re: Setting workpiece zero with G10
Are you using a presetter? I worked for Mori Seiki for 19 years and know the machines well.
- You may not post replies
- You may not edit your posts
Forum Rules
