I dont have the factory option, But I do have a homebrew part conveyor. I tied mine into the m73-m74 part catcher.
I couldnt find a m-code in the book for the conveyor.
Hi
would anyone know whats the M code for moving the part Belt Conveyor to move forward?
mahcine is NLX2500/700 series..
regards.
ok thanks for trying...
it is M200 for that machine
Press the help button, m and g codes are listed.
Sent from my SM-T813 using Tapatalk
M200/M201 are the CHIP conveyor commands
HI ya the M200 is for chip conveyor however I am afer the M-code for the Part Belt conveyor that catches all the finish parts...
have you tried tracing the wires back and see where they land in the magnetics cabinet? Using your ladder diagram and so forth?
Sorry. I misread the original post. As far as I know, the part conveyor is built into the M code for the parts catcher. That is if the parts conveyor came from the factory with the machine. If it is an aftermarket install then it will be tied into one of the External Output M codes. The external outputs for the NLX2500 are M440 thru M449. You can try one of those M codes. Assuming they tied into one of the External Output M codes.
