Originally Posted by
Cartierusm
So I think I'm going to retrofit my 1978 Mori SL1. If any of you have a similar machine I would like some help as to the systems I have to hook up.
1. On the right side is an oil tank and pump that goes to the spindle. I'm assuming it's either dedicated lubrication or cooling for the spindle. My question is does this run all the time or only when the spindle is on?
2. The auto Oiler in front; mine says Lube Corp Model IT. Does it run all the time, or is the CNC controlling it or does it have it's own built in timer?
3. The hydraulic system has quite a few lines I haven't traced them all, they obviously go to the Spindle for chucks or collet closers, it also goes to the tool changer and tailstock center. What else is the hydraulic system controlling and for that matter how does the tailstock itself move and lock down?
Then there's the standard stuff, servos with encoders for X and Z, spindle motor with encoders, limit switches and homing switches, Coolant Pump.
If there's anything else you can think of I appreciate the input.
