Results 1 to 9 of 9
Thread: Researching the G540
    Apr 2011
    united states
    Thanks Group for your input on the Gecko G540 driver.
    I've been looking at a lot of dealers selling the G540 and found one on E-bay (new). he states that he is offering the G540 with complete motor connector set of four 9-pin modules, a complete set of 1/4 watt voltage control resistors. he states absolutely needed and not supplied by Gecko.
    How much additional parts and wiring am I expected to do?
    Also looking at keeping the price down since I spent more than I thought on the first driver set. Is there a 2nd choice that you can recommend ?
    Just looking for a heads up, no surprises , not having to go back out and buy additional parts and pieces, if you know what I mean.
    Once again thanking you all for your support
    jerrywi
    Jul 2011
    Which dealer is it?
    You do need the resistors
    Mar 2003
    Shelby Twp, MI....USA
    The connectors come with the G540. Resistors cost about $1. You wire the resistors into the connectors, along with your motor wires.
    Oct 2004
    Quote Originally Posted by jerrywi View Post
    jerrywi
    Be sure to look at the GeckoDrive website. In particular go to this page of Application Notes and look at 'G540 Initial Setup Guide'. Also look at 'Stepper Wiring'. There's no guessing allowed in wiring. You either understand what you're doing or you don't. Gecko drives are extremely well documented. Take advantage of that and ask about what you don't feel you understand.
    Chris
    Apr 2011
    united states
    Hello Group:
    The dealer I believe is Hubbard CNC Inc.
    Jul 2011
    Hello Group:
    Great dealer. That's where I got mine from.
    Registered Walky's Avatar
    Jul 2009
    Chile
    Quote Originally Posted by SpeedyDad View Post
    I agree, very good seller.
    Another seller I've had a good experience with when buying a G540 is Automation Technologies (Keling).
    Registered momus_cnc's Avatar
    Dec 2006
    I wired my own G540 cables, and rather than individual resistors I used the EZ-G540 from Soigeneris. It is a DB9 connector/backshell with an integral potentiometer. Great product, and makes soldering easy too.
    EZ-G540 - Set of 4
    I bought the G540 from Keling, and had good service from them. I've purchased many other things from HubbardCNC and have always had fantastic service from them.
    -Bob
    Apr 2011
    united states
    Redarching the G540
    Great Info Group
    I did not know about the EZ-G540, so with a set of these I don't have to wire my own resisters?
    I will order the Gecko G540, the EZ-G540 and some cable wire.
    Once again this group has pulled me out of trouble. Thanks
    Jerrywi
    1. Newbie- Researching new build
      By Torontocnc in forum DIY CNC Router Table Machines
      Last Post: 04-23-2012, 12:05 AM
    2. Researching CNC
      By iscnc4me in forum DIY CNC Router Table Machines
      Last Post: 10-13-2010, 02:17 PM
    3. Newbee researching machines to buy.
      By democracyman in forum Knee Vertical Mills
      Last Post: 05-07-2008, 07:45 AM
    4. Researching Things
      By DDaland in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 04-05-2008, 12:41 PM
    5. Newbie, needs help researching cnc mill infomation...
      By Clueless in forum General Metal Working Machines
      Last Post: 05-05-2006, 12:09 PM
