Results 1 to 7 of 7
Thread: Drill Press
    Aug 2011
    Drill Press
    So I have discovered that when drilling the aluminum that my drill press is not as accurate as I am.
    The process that I have been using is to center punch -> spotting drill bit -> drill bit. The spotting drill has really improved the accuracy of the hole. Just passing on some things that I have learned while building this machine.
    Nov 2007
    Quote Originally Posted by Upnxwood16 View Post
    Are using a center punch for the drill press as well? This is most certainly a step everyone should do for drilling any metal whether they use a drill press or not. Same goes for your spotting hole.
    Aug 2011
    Yes I was center punching. After doing just that and drilling, I was getting .04 to .07" variance in the holes. So I used a spotting drill after the center punch and getting .004" between all the holes now.
    Was just sharing my experience as this is my first time dealing with metals.
    Quote Originally Posted by jckstrthmghty View Post
    Nov 2007
    Ah I misunderstood the post. Thanks for the clarifcation.
    Nov 2005
    America
    Optical center punch
    Here is a link for a valuable tool I used for my Momus build.
    http://www.leevalley.com/US/wood/pag...,42311&p=45502
    Aug 2011
    Quote Originally Posted by mlmcquiggjr View Post
    Veritas® Optical Center Punch - Lee Valley Tools
    That looks like a nice tool. Something that I will have to keep in mind.
    Mar 2012
    I also used a Lee Valley centre punch. An incredibly handy layout tool.
    1. Need Help!- Drill Press
      By rwhubbard in forum Want To Buy...Need help!
      Last Post: 10-10-2010, 05:15 PM
    2. Need Help!- Drill Press
      By SheldonB in forum General Metal Working Machines
      Last Post: 04-11-2010, 03:51 PM
    3. drill press mod
      By tbenefi33 in forum Wood Lathes / Mills
      Last Post: 02-24-2009, 05:49 AM
    4. Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press.
      By Geof in forum General Metalwork Discussion
      Last Post: 02-01-2008, 02:32 PM
    5. Drill Press or Mill/Drill?
      By cbcnc in forum Benchtop Machines
      Last Post: 03-05-2005, 06:03 PM
