Hmmm, could be a PSU/drive issue like you mention. I believe the Sherline CNC mill uses only 150in-oz steppers (unipolar) with 10TPI leadscrew, but is capable of milling steel.
I would also check that all your connections are secure/tight. I
just had an incident where my X (gantry) axis looked like it was stalling, until I saw some arcing in the molex connector at the motor. After crimping the female connectors slightly, I go t a good connection, and taped the connectors together. No more problem...
LinkBack URL
About LinkBacks
