Results 1 to 2 of 2
Thread: X Rail Height
    May 2011
    X Rail Height
    It looks like the height of the X rail above the top skin (the bed) is too short. Looking at how my router will mount and figuring the height of a spoilboard and length of a cutter, and I think I should stretch sides by at least 1". In other words, the right inner skin should go from 9" to 10" or more, with everything else stretching to match. If I go with the stock dimensions, I might have 3" or less of usable Z axis travel. That would be enough 95% of the time for me, but it would be nice to have a bit more.
    Has anyone else made this mod? Anyone with a completed machine had a problem with the limited Z travel?
    Registered momus_cnc's Avatar
    Dec 2006
    Yes, depending on tool length and spoilboard thickness, it can eat into the useable Z travel by up to a couple of inches. With my own typical setup, I end up with around 3.5" of Z. It always feels a bit strange when I'm using a very small end mill, and suddenly I gain an extra inch or more of Z travel.
    The next revision of the plans will actually do exactly what you are describing: raising the sides by a little over an inch. The downside to doing this is that when you have work that is down close to the bed, like cutting simple 2 1/2d profiles out of thin flat stock, the router is hanging farther down below the gantry. This gives it a longer moment arm, and it could potentially cause issues like chatter if you are cutting something hard like aluminum. I think raising the sides is a good mod, and I would go ahead with it, but you might want to think about installing a thicker spoilboard if most of your work needs less than the full Z travel. This will keep things more rigid. The spoilboard could be built up in layers that would allow you to quickly remove some thickness on the occasions when you need full Z travel.
    -Bob
  1. TM-1P height
    By jeffrey001 in forum Haas Mills
    Last Post: 06-23-2011, 02:22 AM
  2. New Machine Build- Questions on rail covers, dual servo hunting,and rail preload
    By Plugger in forum General Metal Working Machines
    Last Post: 05-14-2011, 12:00 AM
  3. Newbie- G54 Z Height
    By Deadwood in forum GibbsCAM
    Last Post: 01-03-2009, 03:50 PM
  4. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 02:32 PM
  5. Need Some Help - Gantry Height...
    By JavaDog in forum DIY CNC Router Table Machines
    Last Post: 03-25-2006, 07:48 AM
