Yeah, my router got away from me when I was making the bay openings larger. The door will cover it so I'm not worried.
Yup, the white connector is for connecting the limits and e-stop button. My big red e-stop button will be on the front of the machine.
I got the aluminum standoffs. They work great. I also used them to mount the power supply to have an air gap "under" it. I'll have a fan at the back of the machine that will draw heat out through a hole I've cut. Pics of that later.
I'm thinking of wiring a switch between the power supply and the board so I can shut it off between uses instead of just unplugging the machine. For some reason though, I seem to remember reading somewhere that this is a bad idea. Thoughts?
