I think you're feed rate is low ... you should be able to cut faster. I have seen some people cut at 200 ipm ( plywood). usually stay within 70 -100
So I finally found my back to this forum after messing with my machine quite a bit.
I've managed to go through my first bit and I was wondering if anyone knew what type of bit is best for plywood? The good type of plywood not the crappy kind. I was using a .250 down spiral two flute bit from Home Depot and it was so dull the last time I used it, it overheated and some of the sawdust caught fire. I'm wondering if carbide would be better or maybe 3 or 4 flute bits? Though id ask before I experimented. Also when I cut the wood at 30IPM at a depth of about .250-.360" the noise was unbearable. I would usually make 2 or 3 passes to cut a depth of .725 total. Not exactly sure WTF I'm doing.
-Tom
I'm using the hard plywood, sanded type. Rate is slow yes but is too slow a problem? Ill try it faster once i get a new bit. 30 was just the random rate I decided to start at. Also are you taking into consideration what machine I'm using? I'm using the rigid 2401 router.
if you look at the video of momus CNC on youtube it he's cutting wood at 200ipm 1/4" deep. Cutting wood or plywood shouldn't too different. but I would try better bit and higher feedrate. Try around 50-60 ipm or higher you have to experiment a little but if you go too slow the wood will burn.
I just watched the vid you were referring too. 200IPM on pine 1/4 shouldn't be a problem at all. The stuff I was cutting was much harder than that. Ill post a pic tonight when I get home. I honestly haven't even tried anything faster so I'm not even sure there is a problem. I had already cut a bunch of stuff before i started burning wood. My machine hasn't racked or chattered or anything. I have yet to try it on aluminum.
I did a quick Google search. Take a look at this page and see if it helps:
Calculating Feeds and Speeds - CNC Router Shop
It is in metrics but you can convert
Also look at this thread here:
Feeds, speeds, and bits for plywood
