too bad you did all that sanding, you could have fixed by sliding the rails at the left end of the gantry in a hair and adjusted the bearings that square the gantry on the right. I had a similar issue on the left side but was able to fix by sliding the rails inward and did not need any realignment. Also looks like you have a tight fitting gantry tube, my machine has an 1/8th inch clearance from the right rail, yours looks a lot tighter. Don't worry too much, you will be doing plenty more alignments once you start running things
billj
LinkBack URL
About LinkBacks
